Tv antennas and Tv reception
For the set up you are doing , you can try it with no amplifier at all. If the weak tv signals are to low of signal strength then connect a 2 way splitter to the coax from the antenna , one output of the 2 way splitter will go to the tv 10 foot away , the other output of the 2 way splitter will have a CM3410 distribution amplifier connected and the output of the CM3410 distribution amplifier will have the other splitters connected.
