The U8000 appears to be UHF only, there are two stations that are VHF (both appear to be under 10 miles away). Will both of these stations also be received by the U8000?
Is the use of an amplifier (or preamplifier) needed with the U8000?
I ask about the amplifier because, if I can get the antenna to pull in the longer range stations, I was planning to have the antenna mounted close to one TV (within 10 feet), split the antenna cable to run one line to the TV, then run the second line 30 feet or so to another room where it will be split three, possibly four ways, to four tuners in the second room (a TV, and a PC with three digital OTA/Cable QAM tuners). I assume that mounting an amplifier before the first split is advisable.
