Old 16-Jan-2012, 7:59 PM   #2
Tv antennas and Tv reception
Is this a , house , condo , apt. , mobile home , motor home or etc. . The best for indoor reception is wood with wood or vinyl siding?? Any type or kind of metal siding or stucko with stucko Wire will reduce or block tv reception , Concrete / concrete block / cinder block walls will reduce or block reception , Metal backed insulation will reduce or block reception , A metal roof or metal backed insulation in the attic will reduce or block reception , Solar panels will reduce or block reception , Rocks on the outside or inside of walls will reduce or block reception , Bricks from ground to roof will block or reduce reception.
