Old 16-Jan-2012, 3:14 AM   #3
Tv antennas and Tv reception
WPXH-DT 45 ION Television , is a weak digital channel that is requiring the use of a large antenna. Install outdoor roof top antenna that is strong durable and long lasting outside in the weather. Install a Winegard HD7084P antenna aimed at about 35 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Install above the roof at about 25 feet above ground. Here are some antenna mounts , http://www.ronard.com.909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html. For 1 tv connection no amplifier will be needed. For 2 tv connections use a Channel Master CM3412 distribution amplifier. For 3 or 4 tv connections use a CM3414 distribution amplifier. Here are some places to buy antennas and etc. , http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.solidsignal.com. http://www.starkelectronic.com , http://www.3starinc.com
