Old 16-Jan-2012, 1:31 AM   #5
Electron
Tv antennas and Tv reception
For reception of these American stations , WNPI-DT 23 PBS , WNYF-LD 18 CBS and FOX , WCFE-DT 38 PBS . A Channel Master CM4228HD antenna with a Winegard AP8700 preamp will be installed above the roof and aimed at about 132 degree magnetic compass. . The CM4228HD and preamp , and the CM3016 antenna Will Be two separate antenna systems and Will Not be connected on to one coax. Separate coaxes and separate splitters will go to each tv. A Remote Control A/B antenna switch will be at each tv , the separate coaxes from each antenna and splitter will connect to the A/B switch and the output of the A/B switch will connect to the tv. http://www.saveandreplay.com
