Old 15-Jan-2012, 9:47 PM   #4
Tv antennas and Tv reception
The Canada tv stations/channels are easy. Install a ChannelMaster CM3016 above the roof. Aim the antenna at about 8 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. No amplifier will be needed with the CM3016 antenna. Use a simple common 2 way splitter to connect the two tv's to the antenna. http://www.saveandreplay.com. Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com
