Tv antennas and Tv reception
Most , houses , condos , apartments , mobile homes , motor homes , have coax cable already installed. The coax from the antenna will connect to the coax that is already in place. If you need to run new coax , the coax will go through a Outside Wall to the inside of the house. The coax can also go through a Outside Wall in to the attic.
