Old 12-Jan-2012, 3:47 AM   #3
Tv antennas and Tv reception
This recommendation is based on the Pending Applications Included for the Digital Channels. For reception of the Digital Channels , down to WIVB-DT 39 CBS , in the green and yellow zones all around the compass in every direction with 1 antenna. Install a Channel Master CM3000A antenna. . For reception of the Digital American channels starting at WIVB-DT39 CBS and the American channels right on down into the red/pink reception zone , install a Winegard HD7698P antenna with a Winegard AP8700 preamp aimed at 146 degree magnetic compass. The two antennas will be two separate systems. A coax from each antenna will go to the location of the tv and a Remote Control A/B antenna switch , available at http://www.saveandreplay.com. Buy the HD7698P antenna and AP8700 preamp through , http://www.canadapost.ca/shopper
