Old 12-Jan-2012, 2:23 AM   #26
MisterMe
Originally Posted by trublu View Post
i saw his specification and it say VHF/UHF Antenna (channels 7 - 69), that's mean there is no channel number 2 and 6
it s not important for me to have a HD because my tv is 1997 model so it's not hd. i just need a antenna who can pick-up all the channel, thanks,
For now, you need a 2-69 VHF/UHF antenna. I recommend that you make the leap to a digital TV set. If it is too rich for your blood, then I strongly suggest that you purchase a digital converter with analog pass-through. One will cost approximately CAN$40. Your digital stations will come in with absolutely no snow and no ghosts (mult-path reflections). You may find that the improvement of digital over over analog is as impressive as the improvement of high-definition over standard definition if not more so. The analog pass-through feature will allow you to continue to view your analog broadcasts if no digital version is available.
MisterMe is offline   Reply With Quote
