Originally Posted by jgray972001
Thanks, so you think the K33GX station, an affiliate of KDLV or NBC will be the toughest to get?
I was referring to the digital signal on real channel 26, directly from the primary KDLV transmitter in HD, 1080i plus the second sub-channel. The analog, SD-480i signal from their translator, K33GX should be easier to receive.
Reason: added detail re. differences between HD and SD formats
