Old 11-Jan-2012, 9:05 PM   #7
Originally Posted by 5spdfrk View Post
Thanks for the reply!
The Winegard pre-amp is substantially lest costly than the Antennas Direct one. Are there any major differences between the two? Also, would it be okay to go ahead and install the pre-amp with only one TV or should I wait until I need it?
The CPA-1X amplifiers have slightly better noise figure specifications. I can still recommend the HDP-269 though.
If you're going to use 50' or more cable or install a splitter to begin with, you'll want a preamp. Be sure to install 75Ω F-terminators on any unused splitter ports.
Last edited by GroundUrMast; 11-Jan-2012 at 9:11 PM. Reason: added info re. install preamp now or later
