It sounds as if the trees will not be in the path toward the stations. Hopefully, the attic will not attenuate signals too badly, I would opt for roof mounting.
If you choose to attic mount, I would recommend you use the largest antenna that will fit in the space, while being aimed at 344° compass. Consider the Winegard HD7698P, which would not be excessive if mounted outside in the clear. If you split the signal to multiple sets, a preamplifier such as the Antennas Direct CPA-19 or Winegard HDP-269 would provide more than enough gain to overcome the cable and splitter losses.
