Old 11-Jan-2012, 6:17 PM   #11
Tower Guy
Originally Posted by Electron View Post
The Milky Way ????????????? This technical hair splitting can go on till the end of everything. The result is the question askers are _____________ out of receiving VHF low band channels 2 thru 6 because of the doubt. The question askers are told not to think about it and do not do it.
Please read the following. It specifically states that the Milky Way is the main source of cosmic noise.
http://www.radartutorial.eu/18.expla...s/ex08.en.html
If you want to learn more spend some time Googling. You'll find that the noise temperature of the Milky Way reaches as much as 1400 degrees Kelvin, or an equivalent noise figure of about 8 db. With most good preamps at 3 dB NF or less, an 8 db noise figure due to cosmic noise is not "hair-splitting".
