					Originally Posted by  Bovine0001
				I don't have an amplified antenna.  I live in a suburb with wooden structures.  But, I have ceiling heat which has a significant amount of heating elements in the ceiling.  This could create some problems, I would presume.  So, would the attenuator still help?
 Your heating elements in the ceiling certainly don't help. If you live in the suburbs, then I strongly recommend that you discretely mount an external antenna. You have line-of-sight to strong signals from affiliates for every major broadcast network--and quite a few minor broadcast networks. If you stick with the indoor antenna, then a signal attenuator may help. You may purchase an inline attenuator from
Amazon.com, variable attenuators from
Antennas Direct, and
other reputable vendors. I recommend a variable attenuator.
