Old 10-Jan-2012, 1:22 AM   #13
MisterMe
Originally Posted by Bovine0001 View Post
Well, after lots of fiddling with the antenna I can get ABC, NBC and crappy FOX. I really only want these stations. Would an internal antenna with an amplifier help? I basically wonder if the amplified antennas are any good.
If anything, an amplifier will hurt. You have more than ample signal strength to get ABC (KEZI RF-09), CBS/This TV (KVAL RF-13), FOX/MyNetwork TV (KLSR RF-31), NBC/CW+ (KMTR RF-17), and PBS (KOAC RF-07). As close as you are to several of the transmitters, your reception may be suffering from multi-path signals. I have found that a signal attenuator may help. This is particularly the case if you live in an apartment with steel structure. Transmitters are in two distinct directions from you--33° by the compass and 145° by the compass. You also have stations at 335° to magnetic compass. I would think that an unamplified VHF/UHF indoor antenna would work well. If your antenna is amplified, then my guess is that the total strength being received is saturating the amplifier.
MisterMe is offline   Reply With Quote
