Old 8-Jan-2012, 6:11 AM   #27
Originally Posted by JeffKnob View Post
I picked up the Antennacraft HBU33 from my local Radio Shack and installed it today. My CBS station (WFRV) is now just as bad if not worse than in was. I am also getting a weaker signal overall across all channels. The HBU33 is going back to the store. I am getting very frustrated.
Very frustrating indeed.
I've had tough trouble cases on several occasions. In several situations, I made progress after I decided to start over mentally, throw out all my conclusions and re-prove what I thought I knew for sure.
Each cable and connector, every part of the system should be suspect at this point. I agree w/ MrMe, simplify the system so that you can prove you have reliable signal at the antenna. If not, look for a new mounting location or an antenna that produces a reliable signal. Then, add complexity to the system.
