Old 8-Jan-2012, 12:36 AM   #8
As I look at the path profiles of KARE and K31EF (click on the call sign listed in your TV Fool Report), I tend to think you would see significant improvement if you could use a 50' mast.
You can re-run your TV Fool Report at the higher level to see if there is a worthwhile difference.
Here is yet another method of integrating a secondary antenna into your existing system: http://forum.tvfool.com/showthread.p...4319#post14319
