Old 7-Jan-2012, 10:44 PM   #9
If you and your neighbor are on good terms, you may want to ask them if they use the rotator. For example, sports fans often enjoy receiving 'out-of-market' games by using a large, high-gain antenna and rotator system. If your neighbor is seeing distant signals that you would also want, you'll likely need to use a similar antenna and rotator system.
Otherwise, the less expensive ANT-751, roof mounted, will be plenty for receiving the strong local signals.
