Yes sorry, my rabbit ears have a loop on them. Should have mentioned that. My house is also stucco exterior with wire mesh (I've had to drill into it and it is a pain).
On the roof I can get elevation of about 25'. Is this antenna setup going to be ok without a rotor. A neighbour across the street just had someone come to his house and they installed an antenna that looks much bigger than the one here (although I am sure this one is sufficient) but it will also rotate. I don't know if I should consider that or is that just overkill?
Thanks again for the recommendations, my neighbour paid almost 700 for the install and if I don't need a rotor and can get good signal with a $60 antenna as listed (with shipping) that would be awesome.
