Old 7-Jan-2012, 5:34 AM   #2
Dave Loudin
First, the bad news: you cannot combine antennas like you want to. You must either run a parallel distribution system with a/b switches at each TV, or combine the second antenna into the existing cabling with a Jointenna tuned for channel 27. There is probably enough signal for that station to use the Metrostar in the attic.
