Old 6-Jan-2012, 6:47 PM   #1
silvercity
Help with antenna (Quebec)
Newbie here:
http://www.tvfool.com/?option=com_wr...7fb9e7723714b7
Currently using a DB2 antenna (on the side of the cabin...surrounded by trees) and receiving 2.001, 6.001, 10.001, 12.001, 15.001, 17.001, 24.001 but the signal strength is low. Sometimes we'll get 3.001 and 5.001.... Come spring we may install it on the roof... but for now....
Will changing the antenna to a 4 bow tie antenna, adding a rotor and a pre-amp help signal strength?
Do I need a multi-directional antenna? Was thinking of the CM 4221HD or the DB4 antennas? Not sure if these are multi-directional.
I believe the antennas I mentioned are only UHF antennas....do I need a combo UHF/VHF one instead?
Please help.
Thanks.
silvercity is offline   Reply With Quote
