It sounds as if the location of the antenna and the building construction combine to shield the antenna's view of the stations SSW of your location.
I would opt for a small outdoor antenna such as the RCA ANT-751. If you don't want to do that, you still have the option to try locating the indoor antenna in the attic or at a window with a better 'view' of the available signals. Radio Shack and the home improvement centers stock pre-connectorized RG-6 cables and F-barrel connectors.
Many tuners require that you re-scan to add signals once you have made changes to the antenna location.
It sounds like your tuner allows you to enter real channel numbers directly. Per rabbitears.info, KLSR broadcasts a fill-in signal on real channel 19. For branding purposes, DTV provides the ability to send a virtual channel ID for each sub-channel. In the case of KLSR, your are apparently receiving their fill-in transmitter signal from the NW and your TV is doing it's job, displaying the virtual channel information imbedded in the data stream.
