Old 27-Jun-2010, 9:34 AM   #10
kb2fzq
Originally Posted by schwabrus View Post
I'll make some notes about signal strenth at the current "temporary" spot of about 15' and then at the permenant spot at 30'ish'
One really stupid question. I went to get grounding wire today which was right next to the guy wire. My idiotic self grabbed galvanized steel guy wire without realizing it until after I got back to work. Is it possible to use the galvanized steel guy wire as a ground for my mast?
It's 4 strand, 20 gauge wire. Thought I could twist it to double-up the thickness but not sure if it's idiotic to bother with it.
I would return the guy wire and get solid copper ground wire, copper conducting an electrical charge much better then steel to a ground rod...
