Old 5-Jan-2012, 3:21 AM   #3
Tv antennas and Tv reception
That said , The Canada and USA tv stations Will Be received with a Winegard HD7696P antenna aimed at 188 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. . No rotor needed. . For one tv connection , on coax to the tv . For two tv connections use a simple common 2 way splitter. For 3 or 4 tv connections use a Channel Master CM3414 distribution amplifier. Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html. Here are places to buy antennas and etc. , http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.solidsignal.com , http://www.amazon.com
Last edited by mtownsend; 5-Jan-2012 at 4:57 AM. Reason: Edited to remove off-topic comments
