Old 4-Jan-2012, 6:30 PM   #7
lkruper
Without knowing the exact performance of the RS antenna I can't tell you what the difference will be either. Here is the published spec. sheet for the HD7698P: http://www.winegard.com/kbase/upload/HD7698P.pdf. Currently, the HD7698P offers the highest gain performance available in a combination h-VHF/UHF antenna.
Most SoCal attics get way too hot for any active electronics. If you use any amplifier, I think it best to protect it from extreme heat. A Channel Master CM-3414 or CM-3418 depending on the number output ports needed would be my suggestion.
In the analog days, a signal from an attic mounted antenna would be a bit 'snowier' and have a bit more 'ghosting' but you'd be able to watch it without pixelation or complete loss of signal. The 'cost' of digital TV's 'perfect' picture is that once the signal is too weak or there's too much interference, the picture on the screen goes from 'perfect' to gone as if a switch had been flipped. If we were neighbors, You'd see an antenna or two on my roof.
Thanks for the info. What do you think of the 8-bay antennas like Channel Master 4228HD? I found this site that compares antennas.
*** Edit 1/5/2012 ***
My current thinking is this:
Since the stations I am currently pulling in strong are real channels 7,9,11,13 I propose to leave the Radio Shack Antenna in place and add a Channel Master 4228 mounted as high as possible in the attic with a UHF/VHF Combiner.
This will give me three pieces of hardware that could reduce the signal:
1) New UHF/VHF combiner
2) Existing Satellite Mixer combines Dish Network and Antenna
3) Existing Splitter for Satellite to Dish and Antenna to TV
Would it make sense to replace items 1-2 which are 20+ years old with newer items or items with better specs and if so what would these be?
*** End Edit ***
lkruper is offline   Reply With Quote
