Old 4-Jan-2012, 3:41 PM   #5
lkruper
If the attic is your only option, I'd err on the side of caution and go big. If it will fit, a Winegard HD7698P is not overkill. You need to overcome the edge path impairments and also deal with the penetration losses and reflections of the attic/roof construction.
Thanks, I looked at the specs on that and it is about 1.5 feet longer than my existing antenna. Not sure about width, etc. There is a good chance it will fit. I wish I knew the real specs on the Radio Shack antenna to know how much more gain I will get from this one. In 20 years or so, and considering broadcast was analog at the time, have their also been improvements in design/technology? Also, would you recommend an amplifier?
lkruper is offline   Reply With Quote
