Old 4-Jan-2012, 4:20 AM   #3
lkruper
21.5 dB forward gain does not seem plausible... I've seen gain figures like that, only on a pair of 8' diameter parabolic antennas ganged together, weighing about 150 lbs. I suspect that that figure may be the Front-to-Back ratio. Radio Shack has never been known to hire the top of the class from MIT's electrical engineering department.
My first thought re. reception is, try the antenna outside, above the roof line.
Thanks for the reply. I was actually looking at the roof line this evening. Problem is that it would not fit in, in my neighborhood, not to mention the cost and labor of installation. I am sure, though, that at that height I could achieve what I need as it might even be LOS there.
Do you think that a newer antenna of a brand like Channel Master or Winegard would give better performance in the attic?
lkruper is offline   Reply With Quote
