Old 3-Jan-2012, 11:23 PM   #9
The CPA-19 has slightly better noise performance (it's less noisy). I'd expect either amplifier to overcome all of the loss caused by the splitter and cable in a typical residential installation. That should give you the channels seen when you connected the antenna directly to one set.
You may be able to fine tune the aim and improve your situation a bit more. However, having a general idea of the terrain and Douglas Firs in the area, the ANT-751 is a bit on the small side.
