Old 3-Jan-2012, 8:17 PM   #6
soundbuild
Well, I ran a direct line from antenna to TV, and it worked. That must mean I can't hook it in to the coax that my cable TV was working on.
Will amplifying the signal make it work? I'm trying to avoid running new lines to each TV if possible. It would be simplest to just hook the antenna line in to where the cable came in to the house. Is there any way to make this work?
thanks for the help
soundbuild is offline   Reply With Quote
