Old 3-Jan-2012, 6:35 PM   #1
lkruper
Old Radio Shack Antenna in Attic
Here are my TV Fool results for my location.
I have a 20+ year old Radio Shack Antenna, UHF, VHF, FM in my attic that is 12'6" long. I found the specs here which is for a 21.5db gain.
*** Edit ***
I cannot find an antenna with as high of gain as the Radio Shack Specs. Is it possible that the specs are not realistic?
*** End Edit ***
I went up into the attic and "remembered" that I had put the mast up with duct tape years ago. After a few earthquakes, etc it may have shifted. It was pointed pretty good, but after tweaking it with my TV diagnostics I was able to get channel 7.1 from 85% to 95% and channel 5.1 came in at about 10% which I did not get before. I would really like to get channel 2.1
I get 5.1, 7.1, 9.1, 11.1, 13.1 now all the time and intermittently 28.1 and 56.1.
I have the following equipment between the antenna and the TV receiver.
1) Antenna
2) 25-30 feet of coax
3) A joiner to join my Dish Network Receiver to the antenna
4) About 10 feet coax down the wall to the TV which would be hard to replace.
5) A splitter which takes the signal to the Dish Network Receiver and another to my Slingbox.
6) A short coax from my Slingbox to my TV
Please forgive the formatting, below are my results. I think I can raise the antenna about 3-5 feet. It is currently supported by cross beams in the attic and duct tape around a vertical beam. I have no amplifier. I tried an old Radio Shack amp a few years ago and took it back because I did not see any difference, but I did not have a TV with diagnostics then either.
The last entry in brackets is the new NM(db) and Pwr(dBm) from raising the antenna from 18 to 23 feet. I am not 100% positive I have enought clearance through the support beams to do this. I may only get 2-3 feet at best.
Callsign Real (Virt) Netwk NM (db) Pwr (dBm) Path Dist miles TRUE (Magn) Ant Ht Act TV Signal Ant Ht Max PWR
KVCR-DT 26 (24.1) PBS 56.8 -34.1 LOS 27.9 93 (81) 18 0 23 NC
KABC-TV 7 (7.1) ABC 35.8 -55.1 2Edge 23.5 314 (301) 18 95 23 [40.8 / -50.1] *
KTTV 11 (11.1) Fox 35.7 -55.1 2Edge 23.3 314 (301) 18 Y 23 [40.8 / -50.1] *
KCOP-TV 13 (13.1) MyN 36.8 -54 2Edge 23.3 314 (301) 18 Y 23 [39.9 / -50.9] *
KCAL-DT 9 (9.1) Ind 33.9 -57 2Edge 23.5 314 (301) 18 Y 23 [38.9 / -51.9] *
KTLA-TV 31 (5.1) Cw 26.8 -64 2Edge 23.5 314 (301) 18 2-10 ** 23 [34.9 / -56.0] *
KDOC-DT 32 (56.1) Ind 10.7 -71.1 2Edge 23.5 314 (301) 18 Pix (Int) 23 [27.8 / -63.0] *
KCET 28 (28.1) PBS 16.9 -74 2Edge 23.2 314 (301) 18 Int 23 [24.7 / -66.2] *
KCBS-TV 43 (2.1) CBS 19.5 -71.3 2Edge 23.5 314 (301) 18 0 23 [27.9 / -62.9] *
I will be happy to replace the antenna if it seems prudent, along with coax and add a good powered amp as I have power in the attic. I know the address is not 100% precise, but in taking the height from the existing 18 feet to 23 feet it went from 2Edge to 1Edge. From the DB gain and comparing channel 2.1 to the weakest channel that comes in (5.1) it looks to me that I might get channel 2.1 this way.
One question I had was whether or not I could use a two-input amp and two antenna to get the PBS 24.1 which is line of sight in another direction and should be very powerful at my location, but which I don't get at all. I really need to get either PBS or CBS to get the datastream needed for the Rovi TV guide on my google TV.
Thanks in advance.
My initial plan was to start with new coax where I can replace it and then to add a pream-amp and then finally replacing the antenna with either one or two antennas if necessary. I would be happy with my existing line-up if I could get CBS on 2.1 which antenna web says I cannot get.
lkruper is offline   Reply With Quote
