Hi,
Yes, the preamp is located at antenna, the pwr supply box is near the tv.
I can't verify the Fm trap switch, as antenna does retract enough for me to reach from
roof. It requires laying over the tower, that requires extra manpower.
So.... if I have to pull this tower down I need to convince myself the antenna is good.
Ideally, I would aim at 111 deg, as there seems to be more available, just not sure
the antenna / preamp is up to the task. If a new ant/preamp would make a big improvement, I would consider doing it when I pull the tower.
Chris
