Old 3-Jan-2012, 2:01 AM   #1
soundbuild
New Antenna Installation
Here's my signal analysis - http://www.tvfool.com/?option=com_wr...7fb97606e2c439
I am getting rid of my cable, so I purchased a RCA ant751, mounted it on my eave/gable. Ran coax R6 cable into the house from the antenna, and was hoping I could just hook it into my existing runs of coax cable I used when I had cable tv. Where the cable came into the house I basically had a splitter and then I have home runs to each tv (3 of them), and when I connected the new antenna I didn't get any picture at all. So I tried each tv run separately (no splitter) and still no luck. From antenna to each tv is around 60 -70 feet.
Shouldn't I be getting some sort of picture coming through? I get the black and white static. Is it my antenna installation? TV's? There are currently two tv's, LGLK520, and an AOC L26W661 (hope that's the right number). Eventually a 3rd will be hooked up. Do I need a digital converter box?
thanks
soundbuild is offline   Reply With Quote
