Old 3-Jan-2012, 1:39 AM   #1
Chris05
Newbie reception question
Hi All,
Trying to diagnose a reception problem. I recently located to northern Mn
got a place in the country, picked up a used tower, rotor, antenna and amp
all in good shape and got it setup.
Here is tv signal analysis:
http://www.tvfool.com/?option=com_wr...4033445446e310
equipment:
tower: 20 ft main, with a 20 ft crankup section and 10ft mast on top.
antenna, I believe to be Antennacraft CCS1233 vhf/uhf model.
cable: less than 100 ft from ant to amp.
amp:CM spartan 3, with 2 way split downstream of amp.
Tv: Panasonic lcd with digital tuner and CM Ota DVR.
Antenna is set to 38 deg and approx 30ft in height, nearest treeline is
approx 100 ft away.
Reception: 31.1-31.4 digital, signal is perfect. Analog 29 is grainy.
Problem chan is 13.1, it will not lock at all.
I tried leaving tv set to 13.1 and rotating antenna from 0 deg N to 90 deg E,
but no success.
Today, I even tried setting antenna to 111 deg, and tried for other chans,
no success..... but 31.1-31.4 chans came in perfectly even at this angle.
I am scratch'n my head as to why 13.1 won't show up at all.
Any recommendations?
Thanks,
Chris
Chris05 is offline   Reply With Quote
