RCA
model L32HD31YX12
The coax cable was plugged (screwed) right into the TV.
Same way I have been using the Time Warner cable. No DVD player.
Also, after running into this antenna problem, I replaced the antenna cable with the Time Warner to see if that still worked normally. The new channel search for Time Warner stations took more than 10 minutes, & found 69 anilog stations & 0 digital.
When I checked the stations the sound is normal but they are are so dark I cannot see them
