Old 2-Jan-2012, 8:15 PM   #10
Electron
Tv antennas and Tv reception
Do Not use any type or kind of amplified antenna. If the antenna has amplifier any where , on , in , outside , inside , around the antenna , in front of the antenna , behind the antenna , on top of the antenna , under the antenna , even if you disconnect the amplifier do not use the antenna. No amplifier . The Tv transmissions are VERY STRONG at your location. No amplifier. Being that a antenna is now on top of the roof , aim the antenna at 346 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html
