Old 25-Jun-2010, 12:04 PM   #7
kb2fzq
Originally Posted by mtownsend View Post
Just for completeness, there is a reason for some channels to be stronger closer to the ground.
It is a function of propagation physics. The interface between the ground and the air is an interface between two materials (earth and air) that have different dielectric constants. When radio waves encounter this interface, some of that RF energy will propagate along the surface of the interface before dissipating. Most of that energy stays very close to the surface (usually within about 1 wavelength). When the conditions are right (very low direct signal strength and shallow signal approach angle), the cumulative ground wave energy might be more than the energy in the direct signal itself. When that happens, you might see a little bit more energy close to the ground than you would higher up.
In the real world, this "ground gain" is usually not that helpful. In most cases, as you get closer to the ground, you get more random objects (e.g., other buildings, trees, walls, cars, roads, etc.) that affect your signal. The increased scattering effect will probably negate any gains you might see in signal strength. The ground wave might benefit you if all you have are open fields in front of the antenna, but for most people this is not the case.
If it's just a matter of a few dB, then you are probably better off going with a higher antenna that is above most of the surface clutter, even if it means losing a small amount of signal strength.
Here is a person that knows and understands his RF theory...very well said, mtownsend!!!
I can only add a ground phenominon that I experience every day...my RF 6 only antenna is about 10 feet off the ground. When my girlfriend parks her car under the antenna array, channel 6 will show a 77% SS, when she leaves in her car, channel 6 will drop to 72%, until she returns, then I'm back at 77%. My suggestion would be for the OP to experiment with a temporary mounted antenna at both heights, recording the signal strengths of all stations, at different heights. This will provide real world SS to calculated SS conditions.
Just my 2 cents, but I've done just that myself in the past, with interesting results.....
kb2fzq is offline   Reply With Quote
