At the minimum I just want all the stations I mentioned as well as a few others without them going out all the time,especially when the wind blows (which is the case with the terk hdtvi I currently have outside now). Reason I mentioned 100 miles is cuz i wanted to try to get thecooltv from madison since its no longer available in milwaukee.this table in my yard has a hole for an umbrella,it seems that I can use this to mount an antenna,is there an antenna that comes with a mount thin enough to fit through that hole?
