Old 2-Jan-2012, 12:14 AM   #4
Alright, looking at the path profile for WFSB, it looks like you're facing a similar challenge, but 'on paper' you have even less signal to work with compared to WCWN.
The same recipe would apply, you need more height and the maximum available gain and directivity.
If you're able to consider the option of a tower install, you can run another report based on the higher elevation.
