Old 1-Jan-2012, 9:49 PM   #5
ginginlala
Originally Posted by Electron View Post
Aye, I should have returned to that thread to extend my thanks. Sorry about that. I ended up putting the antenna on the roof of my building, which rectified all problems raised in that original post. The current issue with CBS is new.
As for the amplifier, it's actually not part of the antenna body itself. It's a separate unit connected to the coax that came with the antenna, so I'm simply not using that cable.
The antenna is on the roof, but is probably not elevated far enough. I'm considering purchasing a mast and non-penetrating mount system that can elevate it about 5' (it's currently about 2.5' off the roof).
I may also look at the antenna that was recommended in that thread.
Interestingly, the problem has stopped altogether in the last 2-3 hours. CBS is now coming in at just under 100% on my meter, just like all other stations.
ginginlala is offline   Reply With Quote
