[1 st ? would i still need to GroundMyMast]
I chose to ground my mast and coax, each as separate steps. The ground wires come together only at the electrical service ground. http://forum.tvfool.com/showthread.php?t=901
Have you tried pointing the antenna at KWKB? If reception of their signal is of interest to you, you may find you'll still receive the stronger signals through the back of the antenna.
