Footnote to earlier post
If you decide to keep things simple (no rotator or second antenna)....along with keeping your antenna facing the southwest, I would just keep an eye on the Triad locals. If for any reason you see that your TV is acting up (pixilations and/or dropouts), you *could* consider buying a preamp to boost the Triad signal levels higher.
But *if* you considered this option, you would probably want to keep the antenna facing away from the Triad stations (keep the antenna facing SW). Preamps can cause an overload of signal on a station that is already close to you (i.e. the Level Cross/Randleman towers). As you know, your home is only 23 miles from most of the Triad stations.
