Old 1-Jan-2012, 4:04 PM   #27
DEDon
DEDon's Avatar
I have searched for a couple of hours with no luck to find a guy wire ring/clamp that would allow the mast to turn inside the ring when the rotor turns. I am not going with a tripod mount bc I have a metal ridge vent on the roof and I'm still set on using my supported J-mount as the base mount. I was going to post this elsewhere in the forum but, can't find the right sub-forum to start a thread regarding this issue. Can anyone suggest an arrangement that may work for me, using the current base mount and rotor arrangement?
Winegard HD7084P antenna
ProBrand Int'l RTR100 rotor
Winegard Boost Pre-Amp
Viewsonics VSMA 601C-10R Amp
Samsung 55UH8500FXZA
DEDon is offline   Reply With Quote
