Old 1-Jan-2012, 2:05 AM   #5
Tv antennas and Tv reception
Not close , dl says , The 4228 is a pretty good antenna , so simply replacing it with a 91-XG won't make enough diference. gum says that the 91-XG is better to use then 4228. And gum is also suggesting to use 3 antennas. . I recommend one antenna , a HD7084P that receives All the digital tv channels , 2 thru 6 , 7 thru 13 , 14 thru 69.
