Old 31-Dec-2011, 5:33 AM   #3
Electron
Tv antennas and Tv reception
Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html , Aim the antenna at 168 degree magnetic compass. Also the antenna needs to be level with the ground , Not pointed up at the sky , Not pointed down at the ground , Not tilted to the left or right. What is the model number of the antenna?? In any event the antenna will need to be higher then the roof.
