Old 31-Dec-2011, 12:33 AM   #5
If you choose to install in the attic, use a larger, more directional and higher gain antenna. Attic and roof construction never helps reception and often severely limits it. TG's suggestion of the HD7694P is an excellent example.
I can not recommend an omnidirectional antenna, especially if you intend to attic mount. Omnis have little if any ability to deal with multipath interference, a very common problem in an attic installation.
