Given the nearby trees and buildings, I would opt for a roof mounted antenna. If you want to try for reception of WOCK, real channel 4, a Winegard HD7015 or HD7080 would be appropriate.
At a minimum I would use an RCA ANT-751, the Winegard HD7694P would be a premium solution, though not overkill IMO. (These antennas lack support for real channels 2 - 6)
All of these antennas will be better at dealing with multipath than the antennas you've mentioned.
Reason: Sp.
