Old 23-Jun-2010, 1:51 AM   #6
Dave Loudin
Whoops! You're right. I overlooked the Toronto azimuth. You should double-check your report via the maps option to be sure you have the right terrain effects accounted for. Those stations are lurking at just-positive noise margins, so you will need real antenna gain in that direction. What you may be able to do is use a directive antenna like a Winegard 7696 or an Antennacraft HBU-33 or -44 and catch the US stations with side/back lobes.
