Thanks for the updates!
I believe this swap between KTXA and KPFW has already happened. I think it took place late last month or early this month. This change is already set to take effect during the next database update cycle.
Do you believe that KNAV is currently on the air on channel 12? It seems like that would conflict with KXII. If anyone can confirm that KNAV-LD is on the air, we can add it to the database. We will remove the defunct analog record in the next update.
