Old 16-Jun-2010, 10:02 PM   #10
Lightbulb Tv reception
No distance is to far , cable tv is and example of moving Tv signals over long distances on a coaxial cable. . My aim is to make the cost reasonable with your situation. . 2 channels will be easy to receive in the open area. 48DB-D UHF channel 48 PBS and WIBU-LP UHF 51 ION . . The Oak trees tend to grow 50 , 60 feet and even higher. So the Tv antenna is headed for the open area. . I am thinking about and doing research on the situtation. With the right equipment the Tv transmitters , 6 channels , at Madison to the south can be received. Those are WKOW ABC , WISC CBS , WHA PBS , WMSN Fox , WMTV NBC and WBUW CW. You can go to the >>Start MAPS<< part of tvfool and see the locations of these Tv transmitters. . . You can mull this over for awhile , and I will be back with more info. . But then you have this place in the middle of Nowhere so as to get away from it all , or so you say.
