Thanks for the info. The monoprice antenna amplifier doesn't seem to work anymore (the LED light is off when plugged in) so I've been using it without amplifying.
Maybe I just need a different antenna and maybe I should just put an antenna at each tv instead of using the wall cables.
I'll get a new antenna and see if it helps and get back to the forum.
